查看: 428|回复: 0
air max pas cher enfant not to make a circle
135
453
中级会员
Rank: 3Rank: 3
发表于 2016-1-26 08:46:28 |显示全部楼层
the Air Force immediately sent him to the nearest hospital for treatment. Although the passenger fell to the ground from a height of several kilometers,barbour, but because there is a parachute protection, he did not suffer any harm. At the same time, although the pilot Colonel Lawrence was also stunned the accident, but in the end he managed to remain calm and safely landed the aircraft at the Air Force Base. No injuries considered lucky It is reported that the man touched the joystick is "Pilatus PC-7 type" fighter standard configuration for pilot and passenger evacuation in emergency situations. The flight experts say, the passenger after being "shot" out of the aircraft actually still survived unscathed called lucky. One expert said: "He is so lucky, and did not suffer any harm following the usual special you must receive special training in order to be safe to use 'emergency exit seat' will exit the aircraft themselves." A retired Air Force flight instructor,zanotti pas cher, said that the man was probably dressed in a flight suit, wearing a helmet. Bear when he ejected from the aircraft can be equivalent to 20 times the gravitational acceleration, and it is fortunate unharmed. "Just pull the ejection lever 2.5 cm, you will pop out of the machine. You'll feel subjected to violently push back," This instructor said, "Then,chaussure giuseppe zanotti, the seat is automatically separated from the pilot, the parachute opens. This is for Pilots themselves unable (operation) and the design of the catapult. " Given catapult danger, even professional pilots also need to be trained.
it has been "whoosh" sound disappeared in the sky. Stunning is that, according to experts, when the passenger cabin of the moment was projected acceleration exerted on him as high as 20G (ie, 20 times the acceleration of gravity), almost the equivalent of an astronaut during a rocket launch can withstand the maximum impact. It is in this huge force of impact, the passengers in the aircraft rushed to the blink of an eye above the 100 m height,woolrich donna, and then began to like the same weights slammed the ground! Automatic parachute survived As the passengers have not received any flight training,zanotti pas cher, so he almost fainting in the past in the event of the sudden turn of events. But fortunately,nike air max outlet, his body spare parachute automatically opens in a timely manner,bijou pandora, so that he finally returned to the ground safely, unscathed. South African Air Force helicopters,air max bw pas cher, to find the man in the vicinity langebaanweg airport. Subsequently.
October 28, founded in 1968, the South African Air Force,nike tn pas cher, the famous "Silver Falcon" aerobatic team in the daily exercise training base,hogan rebel, well-trained pilots,abercrombie france, Colonel Gerhard Lawrence flying a "Pilatus PC -7 "stunt aircraft, is several kilometers altitude high-speed flight at an alarming rate,hogan outlet, not to make a circle,giubbotti woolrich, flip and dive and other difficult action. According to reports, the plane was in addition to the pilot, Colonel Lawrence,giuseppe zanotti paris, and one of his friends. According to reports, the passengers are non-military personnel, he had no flying experience,hollister online, but after obtaining special permission from the military boarded the plane stunt plane,scarpe hogan, the media did not disclose their names. Obviously, Colonel Lawrence wanted his friend a good experience aerobatics "stimulus feeling." "Rocket Man" turned out the cabin But let Lawrence Colonel absolutely did not expect that this friend experienced a more "stimulus" experience - he had like a 007 movie "Rocket Man" generally "shot" out of the high-speed flying aircraft. According to reports, when the aircraft during aerobatics dazzling burst of continuous air tumbling action, which passengers feel waves of dizziness, body toward the front seat. In order to make their bodies remain stable, he subconsciously hand caught a lever between his legs, trying to keep balance. Unexpectedly, it was the ejection device joystick. Enabling the passengers never dreamed that he inadvertently pressed the "emergency escape ejection seat" button on the joystick. Blink of an eye, two "Emergency Rocket" he sat beneath the seat ejection seat had ignition launch,chaussure giuseppe zanotti, while the passenger seat both man pop windshield glass,tn, the same as the shells were fired cabin! Moment "cupola" 100 meters According to Colonel Lawrence recalls that when his friends and even had time to issue a call for help.
相关的主题文章:
   http://www.xmarks.com/s/site/www.tadayumi.sakura.ne.jp/apeboard_plus.cgi/
   http://eye.catfood.jp/kousin5/apeboard_plus.cgi?command=read_message&msgnum=40//鈥?/
   http://www.zhushihuisuo.com/home.php?mod=space&uid=2014547561
   http://baowenxue.com/apps.php?q=diary&a=detail&did=118495&uid=11841
   http://periscopewebvideo.com/user/133040/fbconnect
   http://usr.cc/home.php?mod=spacecp&ac=blog&blogid=
   http://cand.qee.jp/link_p/apeboard_plus.cgi?command=viewres&target/
   http://bbs.superdata.com.cn/home.php?mod=space&uid=59916&do=blog&quickforward=1&id=827237
giuseppe zanotti sneakers[url=http://www.reg
GMT+8, 2020-11-25 05:10 , Processed in 1.104475 second(s), 23 queries .
